Could you let me know what you did, or what program you used to edit the data? Maybe I'm doing something wrong, but it definitely didn't work for me.
I used Notepad++, and simply replaced the text string.
Hello all,
How can we modify dano's script so that it would also retrieve information fields such as 'genre' 'country of origin' ?
Thanks all
I've made a separate script based off of the original script, it receives Lyrical Themes, Country, Formation year and Status
_b_Metal_Archives___Band_Info.src (2.72 KB)
Thank you very much sir ![]()
I tried to edit your script to retrieve 'genre' field information with no luck
Since i don't know anything about coding the result ireturned with a error.
#GENRE
outputto "Genre"
findline "
findline "
findinline "
sayuntil "
Strange that it doesn't work, I just did that with mine and it seems to work, might be that my genre section is prior to lyrical themes.
b_Metal_Archives___Band_Info__genre.src (2.83 KB)
Your order works .)
Thank you for your help
May have forgotten my login but It's me DaveyJones again.
I've updated both scripts slightly.
Album Script now retrieves the ISRC from metal-archives
Band Script has had some frustrating amount of time put into it.
It now shows a list of artists with a country and genre tag when searching (Similar to how album script does it.)
It also now retrieves Location tag.
I'm still not really used to writing scripts for this especially when I'm adapting someone else's script but let me know if there's anything else that people want.
_a_Metal_Archives___Search_by_Album.src (5.46 KB)
_b_Metal_Archives___Band_Info.src (3.49 KB)
Put this request out there at one point but it seemed to fall by the wayside and I am unable to figure it out myself...any assistance would be appreciated...
New Script request OR assistance on modifying existing script
Hi! Good evening/night/day.
After watching this thread, and being inspired by both @dano and @DaveyJones2, I took the liberty to create a Github repository with the original versions of the scripts, plus a couple of fixes.
I though that it could be great to have them available on Github because in that way we could collaborate improving them, and/or fixing things when (if) the MA layout changes.
I hope that it isn't an issue to @dano, and if its the case, please let me know.
Also any comments, suggestions, are welcome.
Regards!
A little update:
[FIX]: Fetching Artist tag, as it was detected that the content of the artist/band wasn't on the expected location (thanks to Melvinkooi @ Github).
Is there a way to implement those two scripts (both metal archive scripts by dano and modified by camzo) into one script?
One script retrieves informartion such country, year, info et. while the other script retrieves infos such as artist, album, band url etc.
Thanks in advanced,
Files.zip (3.7 KB)
Hi! Sorry for the late reply... Somehow I'm not getting the notifications on my email
Well, funny enough, I was just wondering the same just today... I'll take a look on how the scripts work to see what can be done.
Also, today I've made some minor updates to the scripts:
- Fixed Additional Info with additional HTML tags
- There was a couple of HTML tags that were passed on. This fix removes them.
- Added extraction of Catalog ID
- This is more a personal request, as I was working early on the morning with some Video Game soundtracks, and wondered if the extraction of the catalog could be done with MA as with VGMDB. Well, it seems that if can be done
The script created by dano on 2007-12-15 - modified by camzo on 11-09-2017 & 02-12-2017 returns an error
Could it be fixed? _b_Metal_Archives___Band_Info.src (3.5 KB)
Hi!
Well, that's weird... Have you tried access to MA through a web browser?
Anyway, if no one is available, I'll take a look into the script this weekend to see what could be the issue.
Best regards.
Thank you for your interest
There is no problem with the browser, all the sources attached work fine except Me&tal Archives#Search by 01. Band_NEW (album-country)
Best regards,Me&tal Archives#Search by 01. Band.src (5.1 KB)
Me&tal Archives#Search by 02. Album.src (5.2 KB)
_a_Metal_Archives___Search_by_Album.src (5.5 KB)
Me&tal Archives#Search by 03. Band Album.src (5.1 KB)
b_Metal_Archives___Band_Info__genre.src (2.8 KB)
Me&tal Archives#Search by 11Album.src (5.3 KB)
Me&tal Archives#Search by 11Band Album.src (5.3 KB)
Me&tal Archives#Search by 11band.src (5.2 KB)
Me&tal Archives#Search by antonio_Album.src (5.2 KB)
Me&tal Archives#Search by antonio_Band Album.src (5.1 KB)
Me&tal Archives#Search by antonio_Band.src (5.1 KB)
Hi there!
@slayerist could you test the attached source? I've updated it, and done some (successful) tests, but I would like to know if it works on your side.
And by the way, about a previous post that you made while ago, since then I done some tests, but it seems that isn't possible to merge both functionalities into one, or at least I'm not aware on how to make it.
@DaveyJones2 it could be possible to add you script "Band Info" into the Github repository? What do you think?
(I ask for this particular script as is the same as the one that I'm attaching in this post)
Thanks in advance.
Regards.
Me&tal Archives#Search by 01. Band_NEW (album-country).src (3.7 KB)
Thank you so much! It works flawlessly right now
This is a bit of a long shot since it looks like the last time you posted here on the MP3tag forums was in 2018... but here goes!
Is it possible to update the script to pull disc number and the bonus track flag?
For example the last track on The Boats of the Glen Garrig by Ahab is a bonus track and is denoted by an asterisk.
Looking in the HTML it's not included in the same string as the title but seems to be flagged separately.
HTML for the non-bonus track To Mourn Job is
<td class="wrapWords">
To Mourn Job
</td>
HTML for the bonus track is
<td class="wrapWords bonus">
The Light in the Weed (Mary Madison)
</td>
Thanks ![]()
Hello there!
Sorry for the late reply, I actually saw the notification email, but kinda forgotten about it and then it was buried by a dozen of other emails... My apologies!
Ok, so lets see...
For disc number you mean something like what's shown on The Human Equation album? The "Disc 1", and "Disc 2" indicators?
And, for the bonus track "flag" (i.e., the asterisk), do you have something in mind about what the script should do with that one?
As far as I remember, as I haven't touched the code in a while (several things have happened in this last 5 years, and a I left lot of things unfinished/or that I completely forgot about), I think that the script creates/uses some customized tags, so at right now I can think that, if it's possible to get that info in a reliable way, the script could be creating a new custom tag to store that value (is possible, or course), but that's only a first idea.
So, let me know what you think, and/or your comments.
Kind regards.
Edit: I did small correction, but, nonetheless, my apologies for my (probable) horrible grammar here and there
