[X] discogs not working
#1
I installed the latest version of Mp3tag, i.e v2.39. I noticed that Discogs isn't working any more. Whatever I type as artist, it says
"Sorry, no entries are matching your search criteria."
The strange thing is that it used to work in previous versions (I don't remember which one I had before).
Does anyone have the same problem?
Yoran
Tag from (not working)
#2
Same trouble here. No troubles with CDDB (Although support for MusicBrainz would be nice)
#3
You can get an updated script from here
/t/1681/1
or download the latest beta.
#4
PROBLEM SOLVED!!!!
thank you very much
closed #5
