[X] Multi-value storage non-complies with ID3 V2.3
1 Ensure Options, Tags, Mpeg, Write (*) ID3v2.3 ISO-8859-1
2 Load an MP3 file
3 In the track list Artist field, enter aaa\\bbb (which Mp3tag defines as representing multi-values aaa and bbb )
4 Inspect the file in a hex editor
Expected: TPE1 aaa/bbb according to the ID3 spec
Observed: TPE1 aaa plus bbb after the terminator
This is a failure to comply with the spec: http://www.id3.org/d3v2.3.0 says
4.2.1. Text information frames - details
TPE1
The 'Lead artist(s)/Lead performer(s)/Soloist(s)/Performing group' is
used for the main artist(s). They are seperated with the "/"
character.
It's more a real-world interpretation of the specification here. Honestly, the ID3v2.3 is so full of quirks that I decided to use 00 as separator.
I really thought long about this part of the ID3v2.3 spec. While Mp3tag tries to comply with the various specs normally, I decided against it in this particular case.
Just think of AC/DC -- should it be treated as AC and DC? I think not.
P.S. [X] for "Won't fix"
The spec says the separator is /. No "interpretation" can see it saying the separator is $00.
That's really disappointing. There should be a clear warning at the top of the Mp3tag documentation of its audio format spec violations that could cause failures for the user.
If you disagee with the spec and want to make an improved non-compliant beahvour, fine, Mp3tag could have that as Tags option. But instead Mp3tag has added its custom behaviour under what it claims under Option to be ID3v2.3. This is a serious misrepresentation. It is this kind of sneaky and hidden standards breaking that leads to many of the problems I and other users have in tag interoperability between many audio programs and devices, and I am really sad to have to add Mp3tag to the list of programs that can't be trusted.
P.S. for "Won't fix"
OK.
