Ability to add to tag panel on the fly
I am happy that you now include the ability to add pick lists for items like conductor, artist, etc. would it be possible to add the feature of adding to a pick list within the tag panel. For example, if I want to add a new conductor that does not appear in my pick list, could you add the ability to add it right from the tag panel. Thanks.
I've added the option to add custom list values via the Shift+Return keyboard shortcut from the respective Tag Panel field with Mp3tag v3.19c.
The Shift+Del keyboard shortcut removes the selected custom list value.
Thanks very much for doing this.
' I've added the option to add custom list values via the Shift+Return keyboard shortcut from the respective Tag Panel field"
I don't have a return key on my keyboard, so I tried shift + enter and don't see the option to add the custom value. The shift + del shortcut works to delete a custom value however?
What am I doing wrong?
Shift+Enter should also work. You'd enter the custom field value to the respective field and then would press Shift+Enter.
After that, the field should be listed in the drop-down list of the field and at Options → Tag Panel → Edit → Manage...
Hi Florian, I tried this and I see that it works. Thanks for your prompt attention to this.
Bruce
