Adding "totaltracks" tag en mass?
  1. I have a large number of FLAC files I would like to add a TOTALTRACKS tag to. How can I do this en mass? Let's say I have an album with 8 tracks, I would like the totaltracks tag to be "08", or "10" for example.
  2. If I converted said FLAC files(after updating the totaltracks tag) to MP3 files with ID3v2.3 tags, what new tag will the totaltracks become?
Anybody?
The only way to get the total number of tracks is by using the numbering assistant.
if you store the total number of tracks in the tag %track% e.g. 2/10 you could then format a tag totaltracks with the substring behind the slash.
There is no direct way to fill the field totaltracks.
So how would I do that?
Use Mp3tag.
Elaborated ...
Select one file in the Mp3tag file list view.
Open the dialog 'Mp3tag/Actions/Actions/Action Groups'
Click the button 'New'.
Follow the further dialogs.
See also ...
How do I create a new action?
/t/967/1
Create the following Action Group
Begin Action Group Format TRACK#Set TOTALTRACKS
Action #1
Actiontype 5: Format value
Field ______: TOTALTRACKS
Formatstring: %_total_files%
End Action Group Format TRACK#Set TOTALTRACKS (1 Action)
Save all changes.
How to apply the action group?
Select the group of tracks, which should receive the tag-field TOTALTRACKS with the same value.
Apply the newly created Action Group right away from the dialog 'Action Group' or invoke the new user defined action via the main menu, dialog 'Mp3tag/Actions' from the submenu 'Format TRACK/Set TOTALTRACKS'.
See also ...
Tracknummer 3-stellig mit führenden Nullen
Here is a new zip package including an updated set of TRACK and TOTALTRACKS related actions ...
[20110713.Format_TRACK.mta.zip ( 2.27K ) Number of downloads: 71]
Unzip all files into a temporary folder and execute the cmd file to copy all mta files into the related Mp3tag folder.
DD.20110713.0650.CEST
Edit.
Actions ...
Format TRACK#Set TRACK fix 001⁄001
Format TRACK#Set TRACK fix 01⁄01
Format TRACK#Set TRACK var (0)1⁄1
Format TRACK#Set TRACK var 1⁄1
Format TRACK#TOTALTRACKS set from selected files
Format TRACK#TRACK format 1⁄11 to 01⁄11
Format TRACK#TRACK⁄TOTALTRACKS merge into TRACK
Format TRACK#TRACK⁄TOTALTRACKS split from TRACK
[20130106.Format.TRACK.mta.zip ( 3.71K ) Number of downloads: 59]
DD.20130106.1340.CET
Added action ...
Format TRACK#TRACK format 01.01 to 1.1
20131223.Format.TRACK.mta.zip (3.98 KB)
DD.20140120.1627.CET
