The auto numbering wizard does not display correctly, ie, is minimised so cannot be used
I hope something can be done
Happy New Year
Yes: update the program. The issue has been addressed with
3.11d (2021-11-19)
- FIX: remembered dialog sizes resulted in dialog contents partly invisible in certain situations. (#55129)
Hi, I have version v3.11 and its says there is no update available. Have you any ideas?
Thanks again
Get a beta from here:
or wait for the next full release.
Hi, I have just downloaded v3.11f and all is well, thank you so much for your help with this wonderful piece of software
