I got most of the stuff I do regularly in a nice Actions list that I use with just two clicks... except the Auto Numbering... for which I still need to remember and click on AutoNum wizard.... is there any way to nvoke Auto Numbering Wizard from 'Actions' ?
It's possible but only for one album/directory because there's no way to reset the counter
This pads the tracknumbers always with two digits ##/##
Action type: Format value
Field: TRACK
Format string: $num(%_counter%,2)/$num(%_total_files%,2)
This pads depending on the total amount of files i.e. 1/8 or 01/15 or 089/112
Field: TRACK
Forma tstring: $num(%_counter%,$len(%_total_files%))/$num(%_total_files%,$len(%_total_files%))
Thanks, I will give it a shot. Actuallly I like to keep tracks as single digit for 1-9 and then it takes it's own course... should I just replace 2 with 1 in the first one ?
(I don have a real need to keep the counter reset by folder though
