Hello i need to change name of all files and id3tags and replace special accents and characters ą ę ć ź ż ó and others shits to a e c z z o (Serato dj have problem with found files location with special accents)
Im found at forum a post with .mta files Unicode to ASCII and i add this to actions. Scripts dont gives a error but Change name and change tags is 0/23492349... files
if that what you find does not meet your requirements, create yourself a new action of the type "Format value" for the field
Format string: $replace(%fieldname%,ą,a,ę,e,ć,c,ź,z)
THe %fieldname% in my example stands for the field name and should be replaced with the real field name like %artist%, %title% etc.
It would be best if you replaced all the characters in the fields first and then rename the file from the tag fields. Otherwise it could be that you try to rename a file even though the name is still the same - which then leads to the observed behaviour.
Make sure that you have a function call for the _FILENAME that looks like $replace(%_filename%,ą,a,ę,e,ć,c)
If you have filenames and no tag data, I would seriously consider to import the original data from the filename first.
But change only FILENAMES titles and artist is still not changed.. Im need to change it in namesfile and id3tags(but not all mp3 have id3tags) If im add 2 more function to replace TITLE and ARTIST. Then all Time removing all ID3TAGS from my .mp3
If you work on data that is not there, then nothing happens.
Still, the lower 2 actions in the screendump still show an action that does not look as though it makes sense: you put the processed data from the filename into the field ARTIST and TITLE.
I would have expected that if you treat the data in ARTIST that you then want to replace all the characters from the field ARTIST and not _FILENAME.
The same applies to TITLE.
So please update the actions.
