Till now I used the ";" as separator for multiple values and try to change it to "\" (resp. the binary code)
I experienced when I do it with a search & replace action - sometimes it works, sometimes it leaves "Artist 1\Artist 2" in the artist tag without really seperating it. In some cases mp3 tag crashed when I called "extended tags" ("erweiterte tags") via the menu.
If I type the "\" manually (or use the "split tag field"-option) it works again and always.
Is this "wanted behaviour" or a bug?
Why does the search and replace work in some cases and in some it doesn't..?.
