Filter by "No Cover Art"?
Is it possible to filter a group of files to show only ones that are missing cover art?
Thanks :slight_smile:
You can create a new column "Cover" via View > Columns..., set its value to %_covers% and sort by this column to group the files without cover art.
Best regards,
Florian
I know this is a pretty old topic, but I was searching for a way to filter rather than just sorting by "no cover art" and I did not find anything like that posted online.
What I did was using the filter
It shows on screen only the songs that have no cover art.
It has to be an empty string on _covers if you are looking for no covers, it would not work with a 0.
Regards,
Daniela
If you have a look at the online help:
http://help.mp3tag.de/main_filter.html
There is exactly this example for filtering files without cover.
