Filter on " character?
Hi, I've tried this : "$len($regexp(%title%,'[^"]',))" IS 4 to filter on " character but this won't work, but it works on other characters like (-,?,=).
What am I doing wrong?
You want to filter all songs with a " character anywhere in the tag TITLE?
Maybe this existing topic can help you:
Or see here:
Also, see the documentation on Filters:
"It is not possible to filter by strings containing double quotations marks. This is a limitation of the feature."
Thanks for the answer, I want to search for TITLE with a certain number of " characters
If t is not possible to filter by strings containing double quotations marks. Then maybe I can replace the " character with something else and then do the filter?
As you see there is a workaround.
"$ifgreater($strstr(%title%,$char(34)),0,yes,no)" IS yes
Still, it is not possible to filter for the quotation marks inside a string.
Which means that you can filter only for the presence of quotation marks.
You could replace them with 2 apostrophes "->''
