How to automate removing items from artist field
I have a lot of jazz recordings and use online databases to fill out the artist field for recordings. Here is an example of a recording artist field:
Donald Byrd (tp) Hank Mobley (ts) Duke Pearson (p) Doug Watkins (b) Lex Humphries (d)
I would like an automated way to remove each of the instruments in parentheses since they don't really belong in the artist field. For example I would like to replace (tp) with a comma and any item in parentheses with a comma.
Is there any way to do this?
An action of the type: Replace with regular expression containing:
Field:
ARTIST
Regular expression:
Replace matches with:
Would do the trick. However that would replace ANYTHING in braces with a , which might be unwanted.
If you know exactly which instruments are possible, a more specific way would be to use a regex like this:
 \((?:tp|ts|p|b|d)\)
Which matches the instruments in braces and nothing else:
This worked nicely. However, is it possible to get the comma closer to the name. For example:
Donald Byrd , Pepper Adams , Herbie Hancock , Doug Watkins , Teddy Robinson
Notice that there is a space between the last letter of the name and the comma. I would prefer:
Donald Byrd, Pepper Adams, Herbie Hancock, Doug Watkins, Teddy Robinson
Is there a way I could do this?
Are you sure you haven't forgotten the LEADING space in the regular expression?
It is necessary in both variants, also in
\((?:tp|ts|p|b|d)\)
One additional question:
I have a new way of importing this same data and it shows in the following format in this same Artist field:
Mickey Roker\\Ray Bryant\\Sonny Rollins\\Walter Booker (should be two backslashes)
How can I automate replacing the \\ (two backslashes)) with a comma and space: ,
Note that I am using the double backslash only as a separator.
Thanks,
Bruce
Several things:
  • If a problem has been solved, then tell us as we tried to find the solution and want to know whether we were successful.
  • If you have another and different problem, please open a new topic thread.
  • Before you do so, please use the forum search function as a lot of questions have already been answered. See e.g. here:
and if you still have a new question, then please follow
esp. in this case the part about "Formatting".
