I edited the heck out of my mp3 tags a few months back, and wound up with great tags, nearly complete artwork (though often only one song on an album will have none for no explainable reason) and everything looked great.
However there was a huge problem with the mp3s. About half of them now have the wrong times when using an Android phone app to play random songs. This causes major problems, in that the player will still think it is on the previous song while playing the next song (it has a function to advance past silence at end of tracks but it is also glitchy since it sees the silence of the extended times but has varying behavior). If the next song fits in the extra time of the first, it may skip songs from playlists, or wind up with 'dead air' (though its only playing for me).
I found that most of the tracks that this was happening to, were originally ripped from their discs using iTunes over 10 years ago. During my mp3 retagging operation one of my things I did was delete comments. Anyone who has iTunes ripped from those old days is probably familiar with the long code type comments found on their ripped files. Is this the reason now they all have 2 times the true time length (in their header I think)?
Is there any way to correct the times for a massive number of files?
Yeah that is what is the problem now yes. The lengths of the songs are pretty wacked. I have this thing where I make long playlists, and sometimes they are getting pretty messed up by the wrong times. I use Musicolet app on Android and it doesn't always skip (in its now playing view) to the next song, though the audio from the next song plays because of the skip ahead past silence behavior ( I won't call it a feature because I don't know why it does it, it just does)
You can load your playlist in Mp3tag and then save it again.
This should use your "new" song lengths.
(You can easily test it, just use a new Playlistname and have a look if the length fit your songs).
I am not sure about that. I think there may be a huge issue with wrong times in the headers of the files. I want to get them right and I'm thinking about restoring the old iTunes files from an old backup from several years ago, since they are the meat of the stack, however there are a lot of other files that have an extra 13s at the end now or something similar to that. What I need is the files to have the correct times. I need to fix the mp3s times to fit the audio actually in them.
Looking at MP3tag: no.
MP3tag is a tagging program for the tags around the audio part of a file.
Anything about the audio part has to be edited with a dedicated audio editor.
No experience with the iTunes comments? I kind of thought it might have been the reason they got messed primarily. Over 160GB of iTunes files and all have the same 2x of the proper time.
MP3val is a small, high-speed, free software tool for checking MPEG audio files' integrity. It can be useful for finding corrupted files (e.g. incompletely downloaded, truncated, containing garbage). MP3val is also able to fix most of the problems.
I have been using iTunes since the day it became available for Win. And mp3tag for almost as long. I have never had this experience with the song length changing when making tag edits in either program.
The time is calculated based on the actual song length and is not one that can be edited by mp3tag.
Was there anything else done since you ripped these so long ago? Maybe some audio editor function was used to add gaps or blanks spaces?
If you use a free editor like Audacity you can open one of the offending files a clearly see if there is a silence of audio at the end of the track.
I have a lot of these to fix. I know for a fact that my John Mellencamp album was playing at 2x the would be length. If there is a solution I will find it. I was looking for a way to fix all the files at one time. I will try MP3Val. I guess there could also be issues with the Micro SD card. It's hard to tell these problems are not existing on my other phone which has other issues with the app and the files. I guess if I were going to try to reproduce it on your files you could try and delete the comment (a large block of coded information put there by iTunes when it ripped the file). That's what I figure caused my problem with these iTunes files because I deleted all those comments. I figure there must be something wrong because of that.
sure. In fact it is not only the ones from iTunes as I have made a screenshot of some files I have acquired more recently by download or by using mp3 cutter app (android) to slice into individual songs. I made this screenshot and it includes the windows explorer from the removed microSD of the defective phone files instance, the connected phone of the correct phone files instance, and thirdly the mp3tag's opinion of the defective files which does not reinforce the windows explorer's opinion of these files length. Just look at how messed up that seems:
