Where is this feature located? I downloaded the newest version 2.37b and I dont see where the cover can be exported. When I go to File -> Export there isnt a selection to Export the cover. All I have found what was available in previous editions. That when selecting View -> Extended Tags you have the ability to save the cover but not export it?
I have the same question ... I am trying to do 2 things ...
Windows Media Player screwed up my "folder.jpg" files. I am trying to do a bulk extraction to fix them ...
I can manually go in to extended tags, click the floppy disk "Extract cover...", a save as dialog with "folder.jpg" as the default filename will pop up and I can save it, and then move to the next file ...
I want to automate this or do it in a big ass batch ... with close to 1000 albums it is taking forever by hand.
The second part is that I want to do the same thing but create files using a string to name the file.
I tried doing the action as listed above with the string %band% - %album% and I got a 0KB file with the correct name ...
Create an action group 'Export cover'.
Create following action:
Action #1: Action type:Export cover to file Format string for image filename:$validate($trim(%BAND%)' - '$trim(%ALBUM%),%DUMMY%)
Try this first with one file and check if it has done what you want.
If ok, then run this action against the selected files.
This worked beautifully. It did in 30 sec what it has taken 3 hours to get half way through ... How would I get it to do it with the file name folder? replace the strings with "folder"?
Hmmm, one picture per album works, if each file contain only one picture (Mp3tag v2.37d).
Well, for other cases, I don't know.
I think that the cover area of Mp3Tag needs a litle bit more brain grease, it is not well formed yet.
Running an action like this from above against files which have 4 pictures embedded there was following result:
Only the first file is proper named.
The following files are numbered as expected, but let missing the %ALBUM% field.
It will create a file for each track you have selected, so if you select say a whole album you will get multiple art files. The trick I used was to sort by Track Number and then select all of the 1s. I got one art file in each folder containing tracks. Of course I have all of mine organized with full tags ...
A suggestion: It would be nice if we could import/export from/to the (numbered) image types in a file, i.e., only update the front cover (3). Or store an extra back cover (4).
Here’s a list (as far as I know about the numbers, all as hex byte code):
00: Other
01: 32x32 pixel 'file icon' (PNG only)
02: Other file icon
03: Cover (front)
04: Cover (back)
05: Leaflet page
06: Media (i.e., label side of CD)
07: Lead artist/lead performer/soloist
08: Artist/performer
09: Conductor
0a: Band/orchestra
0b: Composer
0c: Lyricist/text writer
0d: Recording Location
0e: During recording
0f: During performance
10: Movie/video screen capture
11: A bright coloured fish (whatever that is for …)
12: Illustration
13: Band/artist Logotype
14: Publisher/Studio Logotype
Of course it might also be nice to be able to set/read the image description (max. 64 characters/image).
Florian ... wonderful work. Best tagger out there. This is a double edged sword, though, because if mp3tag doenst have a feature it really hurts as you wont find it elsewhere
Now about Moonbase's question/request...
I cant seem to find a way to import into a specific cover location. you know, like if i have Back covers in each album folder , is it possible to import them into "Cover (Back)"?
Thanks for a great product (you must get tired of reading/hearing that)
