How do I install the export config?
The *.mte files must be copied in the corresponding profile folder%appdata%\Mp3tag\export
Sampler/VA detection relies on the tag %ALBUM ARTIST%. If you use a different tag, you must replace it in the config.
iTunes and WMP users must use %albumartist%
Export scripts:
html_dano_florian album list (with cover)
Short overview of your albums
Preview
html_dano_florian album list (with cover, no tracks)
Preview
html_dano album list itunes style
Preview
