Moving all my settings to a different os
hello i'm aiming to buy the iOS version for my MacBook. its the first time I'm using macOS software. that's why I want to ask you to guide for the steps I will have to follow so I can move all of my mp3tag settings from my previous (window 10) to my new macOS m4 chip.
thank you.
see e.g. here:
You will not be able to
as they are different for the program versions.
Actions are ok, though.
is there video tutorial with the steps I have to follow?
I don't know of one.
so how do I collect all my data settings and move them to my newer pc?
Mp3tag on Windows:
File -> Save configuration.
Unfortunately, I don't know how to restore the content of the ZIP file on Mac.
Source
This would mean:
Locate the mta files on the PC,
make them accessible on the MAC,
use the "Import" function on the MAC as described in the linked section of the documentation.
