Mp3tag v3.18 released
I've just released Mp3tag v3.18 and wanted to outline some of the new features:
Custom List Values on Tag Panel
You can now configure custom list values per field on the Tag Panel. It allows, e.g., for defining a list of composer names to ensure consistent naming. Or a list of country names or languages if you're storing those. It's still possible to see the values of the selected files if you prefer that, but an empty field on the Tag Panel now always offers the custom values (if set) from the drop-down list.
Technical information field %_id3v2_unknown_frames%
This new information field is set to 1 if the ID3v2 tag of the file contains any of the ID3v2 frames not supported by Mp3tag, e.g., PRIV or SYLT. You can remove those frames by cutting the tag via Ctrl+X and pasting it back via Ctrl+V.
Please note, if you're using the Library feature, you'd either need to force-reload the tags of the files via File → Read Tag or Ctrl+T or start with a fresh library to see the newly added field.
This field can also be used with the Filter or as a dedicated column in Mp3tag's File List.
Download the new version
https://www.mp3tag.de/en/download.html
Support my work as an Indie Developer
https://www.mp3tag.de/en/donations.html
As always, thank you for reading, your interest and your support.
Enjoy and take care
— Florian
