Here are some interesting exports that I created.
When somebody has an idea of a new export or when someone finds a bug, please post them!
I want to thank the following persons:
exports)
exports)
dano for request.
You prefer using pls lists and want one big list for your music directory?
Then just download this pls-playlist export and run it on your main-folder:
SquallLeonhart38_Workingdir_pls_Playlist.zip (402 Bytes)
ALBUMLIST SCRIPT: (final) (last Update: 10-07-2006)
An artist-album listing that was inspired by dano and milka. The script offers many additional features like a link to the artist's homepage (when available) or a sorting without those nasty "The".
Scripts:
SquallLeonhart38_Albumlist_01_html_Art_Alb_Detailed_Listing.zip (6.35 KB)SquallLeonhart38_Albumlist_01_html_Art_Alb_Listing.zip (4.18 KB)SquallLeonhart38_Albumlist_02_m3u_Album_Playlist.zip (470 Bytes)SquallLeonhart38_Albumlist_02_pls_Album_Playlist.zip (440 Bytes)
Help: (Recommended)
SquallLeonhart38_Albumlist_Overview.zip (24.8 KB)
EXTENDED OVERVIEW SCRIPT: (last Update: 10-07-2006)
One big file which gives the opportunity to view all necessary and comfortable tags. You can view up to two different covers and you can even view the lyrics (when written in ID3v2). It also saves the naming of files you use via cookies and so you only need to configure it once in a while.
Scripts:
SquallLeonhart38_Extended_01_html_Album_Overview.zip (12.4 KB)SquallLeonhart38_Extended_02_m3u_Album_Playlist.zip (468 Bytes)
Help: (Recommended)
SquallLeonhart38_Extended_Overview.zip (37.4 KB)
DECADE SCRIPT: (final) (last Update: 10-07-2006)
You now can view your albums and mixes sorted be the year they were released in. It's like the ALBUMLIST-Script and so it offers many importanf facts about your collection. You also get statistics for each year.
Scripts:
SquallLeonhart38_Decade_01_html_Album_Listing.zip (6.46 KB)SquallLeonhart38_Decade_02_m3u_Album_Playlist.zip (464 Bytes)SquallLeonhart38_Decade_02_pls_Album_Playlist.zip (434 Bytes)
Help: (Recommended)
SquallLeonhart38_Decade_Overview.zip (24 KB)
SIMPLE OVERVIEW SCRIPT: (final) (last Update: 10-07-2006)
A simple access to all standard infos and to some further informations of your cds. Like all the other scripts this one has some smart counters.
Scripts:
SquallLeonhart38_Simple_01_html_Album_List.zip (3.25 KB)SquallLeonhart38_Simple_02_html_Album_Detailed_View.zip (4.8 KB)SquallLeonhart38_Simple_03_m3u_Album_Playlist.zip (464 Bytes)SquallLeonhart38_Simple_03_pls_Album_Playlist.zip (434 Bytes)
Help: (Recommended)
SquallLeonhart38_Simple_Overview.zip (39.9 KB)
About usage:
Best download the attached overview files, as they are the help files. They offer some informations about installing and running the script. So they are the first adress.
Helps to know how a tag-field is correctly formatted are:
http://www.id3.org/id3v2.3.0.html &
http://age.hobba.nl/audio/tag_frame_reference.html ![]()
Look here for more information on how to change the playlist format in the exports.
So re-download the script.
