Hi I've just launched MP3Tag and for some reason my installation has changed behaviour, I'm not sure if it was due to an update I did recently. I used to have the same persistent text entered in the comment field when I selected more than one file and can't figure out how I set this up or if indeed the option is gone? Can someone tell me I'm not going mad
This happend in V2.88:
"[2018-05-07] CHG: removed default values configuration."
Meaning: you cannot set a default value any more.
You're not going mad ![]()
Ahh ok! I'll call off the men in white coats for now
Can I ask why it was removed??
see here:
You can have it again with Mp3tag v2.90c, where you can now specify a default value per field on the Tag Panel via "Options > Tag Panel".
Great I'll update tomorrow, thanks!
