%_total_size% => $replace(z0z %_total_size% z0z,0,X)
Result:
104,27 MB => z0z 104
Expected:
104,27 MB => zXz 1X4,27 MB zXz
Problem:
No replacement at all and things after %_total_size% are not even included.
%_total_size% => $replace(z0z $trim(%_total_size%) z0z,0,X)
Result:
104,27 MB => zXz 1X4 zXz
Expected:
Problem:
%_total_size% does not have any unit nor decimal part.
Same behavior can be observed with $regex(), and I'm guessing other (string) functions. Is this bug by design?
