Resizing of adjust tag info splitter
See this here where the line is
I would like to see that too :wink:
Sorry for the duplicate request @Florian.
No problem, introduced with Mp3tag v3.12f.
Thanks for adding this.
Can this size get remembered? It resets to the default on subsequent runs.
It should already be remembered and is in my latest tests. Can you re-check or point to any circumstances where it isn't remembered?
In my case I didn't go ahead with the next step as I pressed cancel so perhaps it only remembers if you go through the process.
Yes, it's only saved if you confirm.
