Some iTunes tags no longer working with v2.92
bug-fixed
#1
Since upgrading from version 2.91 to 2.92, it seems the ITUNNORM normalisation and ITUNSMPB gapless tags are no longer listed in the 'Extended tags' window.
Also, the ITUNESMEDIATYPE is no longer shown correctly - instead of the text value (e.g. Audiobook), it displays a unicode control character (e.g. U+0002).
#2
Could you check 2.92a which, I think, fixed the issue of some missing iTunes fields.
#3
Thanks, just gave 2.92a a try, but no difference sadly
#4
Thanks for reporting the issues, I could reproduce all of them. I only wish you'd have been part of the last beta cycle :smile:
Can you try this version and test it with regard to all your MP4 tagging needs?
Edit: removed download link
#5
Looks like both issues are fixed with that version - many thanks!
One other thing though, I noticed when comparing an .m4a file before and after tag editing (to make sure tags were saved correctly), it had the chpl atom added on save despite the original file having no chapters. Is that intended?
#6
Thanks for confirming the fix! I've found it critical enough to release a new version so the issues are now fixed with Mp3tag v2.93.
Regarding the chpl: I'm writing this now if Apple gapless data is found. The chpl atom is Nero's way to keep gapless data and it's my hope that compatibility is increased by this.
Request: Option to disable auto MP4 chapter generation
#7
No problem - thanks for the quick fix and for this great tool too! :slight_smile:
split this topic #8
4 posts were split to a new topic: MP4 length of first chapter is displayed if chapter display is disabled
closed #9
