Tag info from _directory
Hello
once again i'm on the correct format string needed to pull tag info from a frirectory, i can't figure the string to pulll the following from a directory,
adam ant -england - rock.
my goal is to add the country and genre within the tag. can someone please help with the format string. Thank You
i
Try Convert>Filename-Tag
Format string: %dummy% -%country% - %genre%\%dummy%
Please note that there is no field for country and the %country% will create a user-defined field.
Thank You exactly what i looking for. adding to my list of commands notes. Have a Great Day.
i would like to do this within a action
i've tried both format value and guess value with the provided string with no luck, so what action type should i be providing please, Thank You
If something does not work, it would always be very nice to see a corresponding screenshot.
In general it should work with "Guess value".
i really would do a screenshot but always have trouble sending them to the site so here's what is have
source farmat:
E:%artist% - US - DISCO
guessing pattern
Here are some hints how to get screenshots:
The linked section also asks to use formatting. So, could you follow the instructions, please?
I am pretty sure that there is a backslash between genre and dummy.
What I can suspect right now: I assume that you use the folder name as source.
But if you look at the name of the previously applied function Convert>Filename-Tag it uses the filename and not the folder name.
And I also see a trailing space behind the first hyphen in the source but none in the guessing pattern.
But as all these minute differences are important, I much more prefer a screenshot than a written copy.
exactly i'm trying to pull country and genre from the folder name.
If you have problems with screenshots now, use the same technique that was successful here:
thanks but what i'm looking for is the source format under the guess value
You either have to use the filename as source format or use a guessing pattern that uses the folder name exclusively.
Right now you have the folder name as source but use a guessing pattern that assumes a filename.
So which should it be?
Thank you for wording that question i have it figutre out. i see you can' use convert filenane to tag on folders. Thanks Again.....Dp19 Out
That is not true.
You mixed it up as you supplied a foldername as source but used a guessing pattern for a filename.
Or in more details:
where in the source do you find the backslash that you supplied in front of %dummy% in the guessing pattern?
ok as an action right?
Yes. as an action. But in your example you mixed it up as described.
So, will you show us your original approach in a screenshot?
BTW: if the converter is easier to use - why don't you use the "Manage history ..." function and label that converter string with a name like an action and call it when required?
i pull the backlash from the directory. didn't know about the manage history.
The variable _directory does not have the backslash - and also no string following that backslash.
That is why your guessing pattern does not match.
It would be easiest if you used %_filename% as source.
one more thing and i'll leave you alone how can i do the source pattern for multi folders is that possible. again i'm slowly learning this.
Could you please open a new thread for a new problem?
well its not really a new problem thanks for your help.
