Tag source lookup not working 12002
hi,
i'm trying the rag source in mp3tag 3.29 and and everyone i look under i'm getting the following error see screenshot. i have try this with and withiut the tag panel enabled. so where is the problem? using winodows 11 64bit Dp
See e.g. here:
If you get an "operation timeout out" error, the first I would try is to
File -> Options -> Networking -> Timeout
LyricsLover Thank You for how and where to change the timeout option. ohrenkino thabks as well and you should exolain to fix problems like LyricsLover does simple, Good Day All.
You should follow the forum guidelines in the support section and use the search function before you post.
That would make a lot of my replies for you completely superfluous.
