I have successfully retagged every artist and album and more and found covers fir a big library.
The changes do reflect in tags shown in my windows explorer.
However, in ITUnes and another library I use, it is still the same mess.
I saw I can change some settings with CTrl+O / tags but do not understand much there.
What should I do?
Thanks a lot, Agnes
Play the song in iTunes. Tags update.
Thanks for the answer. It seems indeed the problem is about refreshing tags in ITunes, nothing wrong with this nice mP3tag.
Yet it is complicate to play all files... And I wanted to update before I can sync my IPhone.
Seems some new tagging works sometimes for forcing refresh
Not really. When I want to update the tags in iTunes from time-to-time. I go to the top of the iTunes library list. Press play, leave something nicely balanced on the right arrow key that will keep it pressed. Go for a cup of tea and when you come back your Librarys updated.
with my 70,000+ files it would take a long tea break! There are ways to do this I've read. Consider:
http://blog.chintoju.com/2009/07/refresh-i...es-windows.html
I've personally simply removed the itunes library, then pointed back at the directory with my music and added it back to itunes. Then itunes rereads all the tags and artwork. This could be a problem if you have itunes ratings, playback statistics, etc. These won't be saved.
Thanks, I've learned something new there.
Some of your files may contain APE tags which may case a problem. So set up your settings like this.
Load all your files into mp3tag and hit
(only removes the tag types selected in the remove section of this setting) then ![]()
Then do your little trick in iTunes. Failing that. Go for dinner and do mine ![]()
EDIT: Hit F3 and enter "%_tag%" HAS "APE"
EDIT: Your method described for updating tags inside iTunes doesn't work on windows 7 x64.
Here is an example for a jscript that you can use to update your library:
var ITTrackKindFile = 1;
var iTunesApp = WScript.CreateObject("iTunes.Application");
var deletedTracks = 0;
var mainLibrary = iTunesApp.LibraryPlaylist;
var tracks = mainLibrary.Tracks;
var alltracks = tracks.Count;
var numTracks = alltracks;
var i;
while (numTracks != 1)
var currTrack = tracks.Item(numTracks);
WScript.Echo(numTracks + " of " + alltracks);
// is this a file track?
if (currTrack.Kind == ITTrackKindFile)
// yes, does it have an empty location?
if (currTrack.Location == "")
// yes, delete it
currTrack.Delete();
deletedTracks++;
WScript.Echo("Geloescht " + deletedTracks);
else
currTrack.UpdateInfoFromFile();
WScript.Echo("Updated " + numTracks);
numTracks--;
if (deletedTracks > 0)
if (deletedTracks == 1)
WScript.Echo("Removed 1 dead track.");
else
WScript.Echo("Removed " + deletedTracks + " dead tracks.");
else
WScript.Echo("No dead tracks were found.");
Copy the contents into editor,
Save it to a plain text file with the suffix .js
Right-click on the file and execute it in the command shell (otherwise you will be prompted for every file).
The script will run through your iTunes library and delete references to non-existing files as well as update the data for existing ones, if necessary. It will not add files to the library.
Updating a library of 70000 entries will take hours.
What an active support team!
I found out I could more or less update in ITunes by right click / then bulk edit a stupid tag (comment) and ok. Yet, it seems to work not 100% of occurrences ...
I foudn out I could use MediaMonkey to sync my IPhone (for music). So I kinda give up ITunes!
Yet I am not sure what will happen when I sync the rest...
Thanks for the ideas
Agnes
I assume you mean the link I posted. Haven't done it lately, but my second option, removing an itunes music library and then re-adding music files to the library from scratch should always read the latest version of the tags and art (and use all this in creating the "database" that itunes uses for holding metadata). And I use windows7(64).
Thanks Steve
I have not tested that, I thought of it, but am not sure how to do it. The thing is, if I remove the whole ITunes library I am afraid to lose my Iphone Apps too!
I am also on W7 64
Which file would you then delete?
Agnes
huh? Your itunes library has nothing to do with your iphone apps. Open itunes on your computer. Select ALL music files. right click then select DELETE. Then itunes will ask whether you want to remove from library. You say yes. Then it will ask whether you want to DELETE FILE PERMANENTLY from your harddrive. OF course you want to say NO so it only removes from library only. (Try this with ONE file just so you see how the options work and what it looks like, but when ready, you can do this to ALL files at once).
Once you've deleted all files from library, you'll have an itunes library of no songs. Synch your iphone with this "empty" library.
Then in itunes menu choose FILE > ADD FOLDER TO LIBRARY and choose the top directory of your music library. This will add all those files back, scan for gapless, etc. When it is done, synch your iphone again to pick up the songs again.
This is the brute force way to get itunes to read all the file tags again. There may be easier ways.
NOTE: This should all work fine, but I assume you do have a separate backup of all your music files in case you mess something up. Obviously, you should have a complete backup for other reasons too.
None, create one with the script from post #7 and run it
agree, this is a much better approach than the "brute force" method I outlined.
I have about 50 Smart playlists so that's is a no no.
Yep, if smart playlists based on stats on when played last or ratings, etc. I can see this would be a major headache.
Couldn't get this to work. I copied the codetext into notepad ++ and saved it as a .js in the dropdown box below where I enter this filename. I run it and it opens in dreamweaver. Is there a default way of running this?
Yeah if I can get 'ohrenkinos' method to work to try out then happy days. Don't have to bother deleting anything important.
The trick is not to double-click the file but to use the right-click context menu and then select "Open in command shell".
Double-clicking would be a bad idea anyway as this would (if executed) in a confirmation message box for each file. Rather boring.
The starting option seems ok.
To see any error messages, open the command shell on its own,
navigate with the CD commands to the directory where the script is and execute it.
You should then see any messages.
Please note that you have to have to open iTunes as well and leave it open more or less untouched. If you open e.g. the Information dialogue, the script will terminate.
The normal output of the script looks like a countdown
x of y updated
or
deleted x
It could be that you have to install the MS scripting host.
Tried opening the command prompt window dragging the file into the window which puts the path in without typing and hit enter. The file then opens in Dreamweaver as before. I've looked for a MS scripting host but can't seem to find one out there. Think I will stick to my old method. Could you upload your file and maybe see if that works? Thanks.
