Trying to fix track lengths that are incorrect
I have a bunch of tracks that import to Apple Music (macOS) that show a length of 0:10. The actual track plays in full (doesn't cut out after 10s). If I try to convert "tag - tag" and use LENGTH and _length - _length has the correct value. Save the change anyway and import into Apple Music and it's still 0:10.
Anything I can do to resolve these?
The length is not an adjustable value. It's a technical value that can be read from the file, but not changed with Mp3tag.
If this value does not show the correct value, you can use the methods mentioned here in "Check problematic files for errors" and here.
