OK,
I made this script long long time ago (~2 years or so), i never thought about publishing it but i find it very useful for me, so I decided to do it. I'm not a coder and I made it long time ago, so don't expect me fixing bugs or updating it. However it's pretty much complete (at least how I imagined it) and it works just fine for me.
EDIT: I change my mind, I will try to develop it further.
The idea was to tag & rename large amounts of full releases (ablums, vinyls, ect.), extracting as much information as possible.
Fills these tags:
BANDBANDNAMEVARIATION
ARTIST
ARTISTNAMEVARIATION
ALBUM
TITLE
TRACK
VINYLNUMBER
TOTALTRACKS
DISCNUMBER
DISKNAME
TOTALDISCS / TOTALVINYLS
MEDIATYPE
RELEASETYPE
PUBLISHER
CATALOG
GENRE
STYLE
COUNTRY
YEAR (year only)
RELEASEDATE (full date)
RELEASETIME (not formated)
COMPILATION (Yes/No)
MIXARTIST (Remix)
COMPOSER
CREDITS
WWW
DISCOGSID
MASTERID
<!--sizec--></span><!--/sizec-->
Renames directory and files to something like
[CAT 001] Album Artist - Album (YEAR)
00 Album Artist - Album (YEAR).m3u
00 Album Artist - Album (YEAR).sfv
00 Album Artist - Album (YEAR).txt
A Track 1.mp3
B Track 2.mp3
For Various Artist releases:
01 Artist 1 - Track 1.mp3
02 Artist 2 - Track 2.mp3
This script has a lot of fixes for discogs and extras, so that all you tags and files look alike.
How to use it?
Find your release at www.discogs.com.
Copy it's id (i.e. http://www.discogs.com/Age-Of-Love-The-Age.../release/116283, you need 116283).
Drop your files to Mp3tag.
Delete all present tags (Not necessary anymore)
Run "Tag sources -> Discogs_xml_all"
Paste id (search field sould be like this 116283)
Aplly tags.
Run actions:
- Discogs_XML *NEEDED* to complete tagging, run this first, put it at the top of the actions list.
- MixedCD check this ONLY if you have CD ripped to a single track, otherwise it will mess up your tags.
- RenameLabels rename your files, folder, export .m3u playlist, .sfv checksum and txt release info. If you will uncheck it your files will be tagged, but not renamed, moved, no info exported and ect.
NOTE: Script will move your tagged files' dir to E:\Music_labels\%PUBLISHER% (that's where i store my music). If you do not want that delete last command line in Actions --> 3. RenameLabels, or change dir to which one suits you better.
CHANGES in v2.09:
FIX: Credits fix.CHANGES in v2.08:
FIX: More code fix.CHANGES in v2.07:
FIX: Issues related to renewed Discogs API.
ADD: New field - MASTERID.CHANGES in v2.06:
FIX: Small track numbering issue.CHANGES in v2.05:
ADD: New field - RELEASETIME.
FIX: Tracklisting issues.
CHANGE: improved text export,also .nfo instead of .txt.CHANGES in v2.04:
FIX: DISCNAME bug.
FIX: Minor NOTES issues.
FIX: Improved TOTALTRACKS obtaining method.CHANGES in v2.03:
FIX: DISCNUMBER issues.
ADD: New field - WWW with link to discogs.
ADD: Now you can run actions more than once.CHANGES in v2.02:
CHANGE: CREDITS now is sorted by role (just like in discogs).
CHANGE: Removed artist name variations from CREDITS.
ADD: COMPOSER tag, filled from Composer, Written By,
Music By and Producer.
FIX: A lot track fixes.CHANGES in v2.01:
ADD: Removes Dupe PUBLISHER and CATALOG values.
ADD: Grabs all genres instead if first one.
ADD: If DJ mix is present, it is written to BAND tag.
ADD: Overall credits are separated from per track credits.
FIX: Now TRACK, TOTALTRACKS, NOTES, COUNTRY, MIXARTIST
should work fine.
FIX: More minor fixes.CHANGES in v2.00:
CHANGE: Now you can run actions only once after applying tag
from web source.
CHANCE: All credits go to CREDITS tag, also Remix credit goes
to MIXARTIST tag.
CHANGE: Script should run a lot faster.
ADD: Added name variations.CHANGES in v1.23:
ADD: New tags - SONGWRITER, CELLO, MELODICA, SAXOPHONE, VIOLA, VIOLIN.CHANGES in v1.22:
ADD: New tags - LEADER, ORGAN, TECHNICIAN
FIX: RELEASETYPE issues.
FIX: There was per track credits bug.CHANGES in v1.21:
ADD: Removes up to five dupe tag values like 2x same label,
catalog or credits artist.
FIX: Minor bugs.CHANGES in v1.20:
FIX: More credits issues.
FIX: Minor NOTES fix.
ADD: New tags - CHOIR, DIRECTED, BASS, CONCERTMASTER, DRUMS,
ACCORDION, GUITAR, PERCUSSION, STRINGS, TRUMPET, FLUTE,
ADAPTED, ENSEMBLE, PIANO, MUSIC, SYNTHESIZER, THANKS.CHANGES in v1.19:
FIX: "Empty fields" bug. Script did not work with releases
that had empty date, country or style.CHANGES in v1.18:
CHANGE: TOTALTRACKS field now supports up to 9CDs releases (was 2CDs).
ADD: New tag - DISCNAME.CHANGES in v1.17:
FIX: NOTES formating.
ADD: New tag - COMPILATION [Yes/No]
CHANGE: m3u, sfv and txt filenames.CHANGES in v1.16:
ADD: New tag - NOTES.
CHANGE: Improved cover art fetching.CHANGES in v1.15:
FIX: Credits issues.
ADD: TOTALTRACKS for vinyls.CHANGES in v1.14:
ADD: New tag - TOTALVINYLS.CHANGES in v1.13:
FIX: There was some errors, but now it seem works fine.CHANGES in v1.12:
FIX: Track number issues.CHANGES in v1.11:
ADD: Cover Art Support.
ADD: New fields added: VINYLNUMBER, KEYBOARDS, ARTWORK, PHOTOGRAPHY.CHANGES in v1.10:
FIX: Now saves all credits, including "overall". There was error in actions.
FIX: Properly saves tags witch includes named vinyl or disk sides like this.
FIX: Did not fixed artist names from "Artist, The" to "The Artist" witch
included "(#)" at the end, like this one.
ADD: You can leave your curent tags, script should auto-remove them.
ADD: Auto exports .m3u playlist, .sfv checksum and .txt release info.
ADD: Auto move to dir where i store files.
CHANGE: Underdashes "_" replaced with spaces.v1.00:
First public version.
That's it. I've put a lot of hard work into it. I hope you like it.
Feel free to modify it for your needs.
Also if you need any help, just ask.
Discogs_ALL_API_v2.09.zip (7.84 KB)
