Yes, with light my mod in action part.
Maybe wrong input? Right discogs id looks like 2295371
Hey Pufas,
Don't know if you roam around here anymore? Anyway I just wanted to say that your scrips where absolutely amazing, none has come close since. I actually thing that the 1.x versions where the best and I'm still using the "last" 1.x which was 1.23. Know you felt they got to fat and slow, I didn't agree...
In the end I'm reluctantly using iTunes, it sucks, but it integrates with my iPhone, with iSub and other music solutions I'm using. I've made a few modifications in the script and many, many actions to get the info presented in an optimal way in iTunes. Anyway, me rambling, it's now 1 year ago since you stopped working on it, and 1 year of usage for me so once again, thank you!
Regards,
Matthias
Hey Pufas,
I really appreciate the time you spent on this script, it has been perfect for my needs.
I have a quick question regarding the release of V2.47 and the change of fields from band to albumartist. When I run your script the field "albumartist" doesn't seem to be populated anymore - I am terrible at editing scripts and any advice would be appreciated.
Many thanks.
I think I cracked it myself - I used custom mappings to write BAND To ALBUMARTIST.
Is there any way to add featuring-field from Discogs into artist tag? It's really important in release like this.
I thought this skript writes it into MIXARTIST.
If not, it's maybe outdated, have a look at these: /t/9226/1 or /t/1992/1
Unfortunately, Discogs changed something in the XML API. As a result of corrupted tags actors and roles.
Pufas, we need your help please)
will someone fix the prob? anyone? it's impossible to tag now ![]()
anyone?
Why don't you try one of the other discogs scripts.
You can edit all tag name in the way you want them with my Discogs (Pone Mod).
The only thing you don't get with the non-API scripts are the Main Artist Names. You always get just the Artist Name Variation as given on a discogs release.
I am thinking about making an API version of my script for some time. But I just haven't found the time for a close look at the API pages to see how they are built up.
I've tried your script, but it didn't work.
It does work.
You have to do some installation steps befor you can use it. This is necessary for the script to make it customizable by the users. There is a short instruction in the starting post:
[WS] Discogs (pone mod)
Just ask if you have problems.
Too complicated. Can you modify an old script version? I want it to be simple.
Why nobody cares about this problem? Am I the only one who uses mp3tag?
You say my 8-steps-instruction is too complicated, but you want me to modify Pufas' script!?!
It would take me a lot of time to understand how Pufas' scripts worked, why it doesn't work now, and what I have to change to get it working again.
By the way, have you read Pufas' instructions? His script is not so easy to use. You have to search the release in your web browser instead with the Mp3tag and you have run an action after using the web sources for every release!
There are several working discogs scripts for Mp3tag.
There are also two older scrits from which I don't know if they work, just test them:
What is this suppose to mean?
Tag Sources - Discogs Pone - Search by artist and it gives me this
managed to fix this issue...
my script modified a lot, so I'm not gonna post the whole script.
you need to open up sources/Discogs_XML_ALL.src (or how it's called).
find the line:
# ARTIST
outputto "ARTISTTMP"
findinline "<tracklist>"
and replace with:
# ARTIST
RegexpReplace "<duration />" "<duration></duration>"
also you might need to tweak actions/1. Discogs_XML.mta and replace constructions like , , , , all tags with should be replaced to none.
here is an example for ARTIST:
[#16]
T=5
F=ARTIST
1=$if($eql(%ARTISTTMP%,),%ARTIST%,$replace($replace($replace($replace($replace($replace($replace($replace($replace($replace($replace($replace($regexp(%ARTISTTMP%,<name>'['^<']'*?</name><anv>('['^<']'*?)</anv>,<name>\\\\1</name>),<artist>,),</artist>,),<join>,<join> ),</join>, </join>),<join>,),</join>,),<name>,),</name>,),<join />,),<anv />,),<role />,),<tracks />,))
bigup again to Pufas for this script! been using it for almost 2 years, modified only 3 or 4 times I think, due discogs changes.
mp3taglover thanks a lot!
Fixed script. If you have any issues, post here.
Great news Pufas, thank you very much!
A little bug report ):
no tracklist for some releases:
http://www.discogs.com/release/1421851
http://www.discogs.com/release/1461488
http://www.discogs.com/release/256249
no mixartist (?):
http://www.discogs.com/release/118149
"Various" instead of artist names for many VA releases:
Done.
