My Windows locale is set to French (because of currency, metric, date, etc), but I'm more used to use English in GUI language.
After I installed ver 2.84a, I open it and found that its GUI is in French. So I went to Tools > Options and set Language to English. Upon restarting the software, some part of GUI is still in French as shown in the attached image:
It was wrong to rate it as "no bug" while it is an obvious bug. A simple argument is like this:
Change the language once again using GUI
Restart the software
When the software starts up, observe the labels
Some of them are still in previous language >> BUG
QED
Constant repetition of the same statements does not add value to them.
Please see /t/18800/1 again - there have been amendments, also in response to your post.
