Keyboard Shortcuts
Mp3tag menu
Shortcut Command
⌘ , Preferences...
⌘ H Hide Mp3tag
⌥⌘ H Hide Others
⌘ Q Quit Mp3tag
File menu
Shortcut Command
⌘ O Open...
⇧⌘ O Add...
⌥⌘ C Copy to...
⌥⌘ M Move to...
⌫ Remove
⌥⌫ Delete
⌘ P Create Playlist...
⌘ E Export...
⌘ R Refresh
⌥⌘ R Refresh Tag
⌘ S Save
⌥⌘ S Save (Force)
⌘W Close
Edit menu
Shortcut Command
⌘ Z Undo
⇧⌘ Z Redo
⌘ X Cut
⌘ C Copy
⌘ V Paste
⌥⌘⌫ Remove Tag
⌘ A Select All
⌥⌘ ↑ Select Previous
⌥⌘ ↓ Select Next
⌘ F Filter...
⌃⌘ Space Emoji & Symbols
View menu
Shortcut Command
⌘ T Extended Tags...
⌃ 1 Go To Tag Panel
⌃ 2 Go To File List
⌃ 3 Go To Cover
⌥⌘ T Show/Hide Toolbar
⌃⌘ S Show/Hide Tag Panel
⌃⌘ F Enter Full Screen
Convert menu
Shortcut Command
⌘ 1 Tag - Filename...
⌘ 2 Filename - Tag...
⌘ 3 Tag - Tag...
⌘ 4 Text File - Tag...
⌘ K Assign Track Numbers...
Actions menu
Shortcut Command
⌘ 6 Actions...
⌥⌘ 6 Quick Actions...
Tag Sources menu
Shortcut Command
⌘ I Tag Source...
Window menu
Shortcut Command
⌘ M Minimize
Help menu
Shortcut Command
⌘ ? Mp3tag Help
File List
Shortcut Command
Space Quick Look
Extended Tags
Shortcut Command
⌘ ← Previous File (if only one file is selected)
⌘ → Next File (if only one file is selected)
⌘ N Add Field
⌘ ⮐ Edit Field
⌫ Delete Field
Action Groups Sidebar
Shortcut Command
⌘ N Add Action Group or Category
⌘ D Duplicate Action Group
⌫ Delete Action Group
Action Group Details
Shortcut Command
⌘ N Add Action
⌘ ⮐ Edit Action
⌫ Delete Action
Tag Sources Result
Shortcut Command
⌘ ↑ Move Selected Files Up
⌘ ↓ Move Selected Files Down
Custom Genres Preferences
Shortcut Command
⌘ N Add Genre
⌘ A Select All Genres
⌫ Delete Selected Genres
Custom Fields Preferences
Shortcut Command
⌘ N Add Field
⌘ A Select All Fields
⌫ Delete Selected Fields
File List Preferences
Shortcut Command
⌘ N Add Column
⌫ Delete Selected Column
⌘ ↑ Move Selected Column Up
⌘ ↓ Move Selected Column Down
Tag Panel Preferences
Shortcut Command
⌘ N Add Field
⌘ ↑ Move Selected Field Up
⌘ ↓ Move Selected Field Down
Custom Keyboard Shortcuts
You can also create custom keyboard shortcuts for any command visible in Mp3tag's menus at the top of your screen (this includes keyboard shortcuts for your action groups). These shortcuts will need to be created in your Mac's System Preferences. For more information, see the macOS User Guide: Create keyboard shortcuts for apps on Mac.
