I've just released Mp3tag for Mac v1.8.20 with the following changes:
Changed, Improved & Fixed
Occasional crash due to concurrent read/write access to internal storage.
Tag Sources with Windows line breaks CRLF produced extra empty line for each line break. (#64214)
It's a free update! You can update the Mac App Store version via the Update tab in the App Store app and the standalone version from within the app via File → Check for Updates .
I've just released Mp3tag for Mac v1.8.21 with the following changes:
Added support to add multiple values for fields from Tag Sources
Improved compatibility of Web Sources Framework function RegexpReplace with CR characters (carriage return) in input data.
I've just released Mp3tag for Mac v1.8.22 with the following changes:
Renaming folders to nested subfolders via action Format Tag Field for _DIRECTORY on multiple files was applied on already renamed folder in some cases. (#64628)
JSON-related functions json_foreach and json_foreach_end of Web Sources Framework reverted back to root object and not to previously selected object. (#64047)
Added support for sdes MP4 atom which is mapped to STOREDESCRIPTION.
Added support for detection of AV1 video tracks in MP4.
Added support for Opus in MP4.
Changed, Improved & Fixed:
Filtering based on format string did not always work when format string contained filter operators.
Format string field menu buttons could not be accessed via VoiceOver modifier key.
Selecting an item from the fields menu via keyboard or VoiceOver added it at the beginning of the format string field instead of the current cursor position.
Internal changes to parts that are responsible for reading and writing MP4 metadata.
Updated to FLAC 1.4.3.
Updated to Opus 1.5.1.
I've just released Mp3tag for Mac v1.8.24 with the following changes:
New:
Added option to stop, skip, and rename with apply to all on errors when renaming files via actions.
Choosing Skip and checking Apply to All on errors when writing tags did not skip subsequent files that produced an error.
Update 32-bit MP4 stco chunk-offset atoms to 64-bit co64 chunk-offset atoms if referenced sizes are exceeding the unsigned int 32-bit range. (#65218)
Format string field menu buttons could not be accessed via VoiceOver modifier key for Export and Filename to Tag.
Attempting to delete a file which was already deleted externally resulted in an unnecessary error message.
Added a workaround for possible hangs caused by infinite backtracking of the regex engine when importing a large number of tags from text files and the format didn't match the input. (#65893)
Resolved high memory usage when determining cover sizes of huge covers when loading a large amount of files.
I've just released Mp3tag for Mac v1.8.25 with the following changes:
Workaround for infinite backtracking had unwanted side-effects for matching of patterns ending with characters that are reserved in regular expressions.
I've just released Mp3tag for Mac v1.8.26 with the following changes:
Reloading tags of individual files via File → Refresh Tag or ⌥⌘R resulted in app not responding.
I've just released Mp3tag for Mac v1.8.27 with the following changes:
Choosing Open With from the context menu opened only one file in the target app even if multiple files were selected. (#66291)
