Mp3tag for Mac v1.8 released
I’ve just released Mp3tag for Mac v1.8 and I want to take the opportunity to outline some of the new features and improvements for you:
Copying and Moving Files to Different Folders
This new feature makes file management from within Mp3tag much easier. It comes with support for undo and features advanced error handling, by allowing to stop, skip, or replace on errors with the option to apply the chosen option to all files.
Navigation to Next and Previous File at Extended Tags
Till now it proved to be quite cumbersome to go from the current to the next file in Extended Tags. You had to close the window, select the next file, and re-open it. Direct navigation from Extended Tags simplifies the task of inspecting or updating a sequence of files, where each file needs to be treated individually.
Select Added Files
Newly added files are now automatically selected when loading files. This makes it easier to directly apply actions on exactly those files or simply to spot the newly added files directly.
A few more things
I’ve also added format string histories to all format string fields. This allows for switching between recently used format strings without the need to craft them again or manage them externally. In addition, I've fixed many issues and introduced quality-of-life changes, which are all listed in the Mp3tag for Mac changelog. If something is unclear or sparks your interest, please don’t hesitate to ask.
It's a free update! You can update the Mac App Store version via the Update tab in the App Store app and the standalone version from within the app via File β†’ Check for Updates.
And if you’re not yet using Mp3tag for Mac, you can always get the 7-day trial version β€” only days you’re using the app are counted.
Thank you for reading, your interest, and your support.
Enjoy and take care
β€” Florian
I've just released Mp3tag for Mac v1.8.1 with the following changes:
New
β€’ Added scripting function fmtDuration to create a formatted duration string based on numerical input.
β€’ Added function SayDuration to Web Sources Framework
β€’ Added JSON-related function json_select_many_count to Web Sources Framework
β€’ Added JSON-related function json_foreach_counter to Web Sources Framework
β€’ Added JSON-related function json_foreach_reverse to Web Sources Framework
Changed, Improved & Fixed
β€’ Extended json_select_many with optional parameters for last item separator and max items to select
It's a free update! You can update the Mac App Store version via the Update tab in the App Store app and the standalone version from within the app via File β†’ Check for Updates .
I've just released Mp3tag for Mac v1.8.2 with the following changes:
New
  • Added support for editing Tag Sources configurations via the Tag Sources menu.
  • Added functions IfVar and IfNotVar to web sources framework to check configuration settings from Tag Sources.
  • Added new key [Settings]=Tag Source Configuration.settings to provide a settings schema for Tag Sources.
  • Added new key [MinAppVersionMac] to require a minimum version of Mp3tag for a Tag Source to be used.
  • Added support for audio MD5 via %_md5audio% for WavPack.
  • Composing URLs in Web Sources Framework did not use Encoding and WordSeparator values from Tag Source definition
I've just released Mp3tag for Mac v1.8.3 with the following changes:
  • Tag Source configuration settings were not saved, because required file settings.json wasn't automatically created on first use.
I've just released Mp3tag for Mac v1.8.4 with the following changes:
New
  • Added support for localization of Tag Source configuration settings.
I've just released Mp3tag for Mac v1.8.5 with the following changes:
  • Fetching cover thumbnails via Tag Sources resulted in a blocked user interface, if the server terminated the connection prematurely.
I've just released Mp3tag for Mac v1.8.6 with the following changes:
  • Using web sources framework function findinline on empty input could result in an application crash.
I've just released Mp3tag for Mac v1.8.7 with the following changes:
  • Updated for macOS Sonoma.
  • Menu items File β†’ Copy to... and File β†’ Move to... were also enabled if no files were selected.
  • Extended JSON-related functions json_select_many and json_select_many_count of web sources framework with optional parameter to include result entries for non-existent items.
I've just released Mp3tag for Mac v1.8.8 with the following changes:
New:
  • Added function SayDate to Web Sources Framework.
  • Added support to reference contents of output buffers via %output% in string parameters of Web Sources Framework functions. (#62238)
  • Added special handling for iTunEXTC field name for MP4. (#62556)
  • ID3v2 UFID was not always correctly detected as binary or text-only frame. (#62268)
  • Cover dimensions on Tag Panel were reported as larger size in some rare cases.
I've just released Mp3tag for Mac v1.8.9 with the following changes:
  • Leading and trailing quotes were accidentally removed from parameters of Web Sources Framework functions which resulted in unstable behaviour of certain Tag Sources.
  • Added workaround for WordSeparator configuration setting misspelled as WordSeperator in Tag Sources.
I've just released Mp3tag for Mac v1.8.10 with the following changes:
New
  • Added support for removing only duplicate fields that have the same content at action Remove duplicate fields.
  • Changes that were made in individual files via navigation in Extended Tags were written to a different file in rare cases.
I've just released Mp3tag for Mac v1.8.11 with the following changes:
  • Check for minimum required version of Mp3tag for a Tag Source did not compare all version segments numerically, which resulted in misleading error messages since the last version. (#62902)
I've just released Mp3tag for Mac v1.8.12 with the following changes:
  • Using Web Sources Framework function findinline on strings with non-ASCII characters could in certain situations result in an application crash.
I've just released Mp3tag for Mac v1.8.13 with the following changes:
New
  • Added option to stop, skip, and rename with apply to all on errors when renaming files.
  • Added option to stop, skip, and retry with apply to all on errors when writing files.
  • Added option to stop, skip, and replace with apply to all on errors when copying and moving files.
  • Added support for Dutch localization.
  • File permissions and ACLs were not preserved in some cases if writing tags involved temporary files.
I've just released Mp3tag for Mac v1.8.14 with the following changes:
  • Images added from Firefox via drag and drop could not be saved. (#63732)
  • Using a negative value for maximum number of items to select at json_select_many resulted in a crash. (#47197/19)
I've just released Mp3tag for Mac v1.8.15 with the following changes:
  • Removed normalization of linebreaks when reading ID3v2 frames USLT (UNSYNCEDLYRICS) and COMM (COMMENT) to prevent display problems in Music.app. (#63695)
  • Prevented accidental drop and resulting duplicate of own dragged image when dragging cover art. (#51224)
I've just released Mp3tag for Mac v1.8.16 with the following changes:
  • Added workaround for macOS caching issue on ExFAT file systems related to file names in Unicode NFC form.
I've just released Mp3tag for Mac v1.8.17 with the following changes:
  • Further refinements regarding accessing files in the recommended way of encoding Unicode file names of the underlying file system.
I've just released Mp3tag for Mac v1.8.18 with the following changes:
  • Addressed an occasional crash when dragging cover art from the Tag Panel.
  • Addressed an occasional crash when fields were deselected (via ⌘ Click) from some of lists for field selection.
  • Addressed a rare crash when calculating totals of lengths and size of selected files shown in the status bar.
I've just released Mp3tag for Mac v1.8.19 with the following changes:
  • Resolved high memory usage when applying a quick action of type Adjust Cover on a large amount of files.
  • Copying many files to the clipboard could result in a huge delay on quit.
  • Nero MP4 cdec atom for encoder settings was not preserved when writing tags.
