I use mp3Tag for quite a while, but for some months now, renaming tags from filenames will freeze frequently.
I use MS10 home built 19045.5854
I don´t know if windows is the problem or that mp3tag changed somehow.
and I stopped renaming more then 30 files (in earlier times renaming with some 100 tracks hasn´t be a problem)
is there anything I can do?
(I use the acual v3.30 version, but it startet to get difficult some versions before)
What kind of files are these?
Have you checked the files for problems?
Where do you store the files ? Locally or the network?
Does this happen to the same files repeatedly or do you see the behaviour with different (random) files?
Do you get any messages?
It doesn't matter which file, I tried 4 they were ok, but with my 100drets of tags, Id prefere an errormessage instead of fishing in the dark
And as I said, with another tag manager it worked
What a pity, I love mp3 tag!
It seems that you all dont't have this problem and Im not sure if I'm willing for a new computer
It looks to me as though you cannot reproduce it also, it just happens randomly.
Also, we in the distance have to rely on everything you say as we cannot look over your shoulder.
I still suspect that it is a local problem of colliding applications that quarrel over changed files.
E.g. it was suspected once, that an anti-virus program may block process as renaming a lot of files may look like the attack of a malignant software.
So, you have to investigate, e.g. with the process explorer by sysinternals if there are programs that access the same files that MP3tag does.
