Hello. Firstly, thank you for this awesome software, I have been using it for years.
I recently got a new computer. Windows 11, 64 Bit, Resolution 1920 x 1080
When viewing the 'Auto numbering wizard' window, I can't see all the options, the window is too small and cannot be resized. Hope it can be fixed, thank you. It was fine on my previous machine with a lower resolution.
However, I'll leave it as a valid bug so far. Using settings from one computer on another is a common use case and should not make some dialogs unusable.
