Mp3tag for Mac v1.9 released
I’ve just released Mp3tag for Mac v1.9 and I want to take the opportunity to outline some of the new features and improvements for you:
Support for the Matroska File Format
Mp3tag now has support to view and edit metadata of Matroska audio (MKA), Matroska video (MKV), and WebM files, and thereby supporting one of the most complex metadata formats via a common and accessible user interface. Support for chapters in Matroska is on my internal wish list.
Replace Cover via Tag Panel
If you wanted to replace the existing embedded album cover, it involved a couple of steps (removing old, and selecting new). If the file had multiple covers and you wanted to replace a cover, even more steps were involved: in addition, the existing covers needed to be exported and re-added. This is a thing of the past, and the currently displayed cover can now easily be replaced via Replace from the right-click contextual menu on the cover window.
Improved Keyboard Navigation at Tag Sources
I've reworked the Tag Sources search window to use the Search button as the initial default button. After results have been queried, the Next button acts as default and responds to the Return key press. Tab navigation order has also been improved and it should feel more natural now to use the Tag Sources search via keyboard.
A few more things
Mp3tag is now localized to Danish — mange tak to @Littelking! I’ve also improved undoing cover operations and changed many of the converters, e.g., Tag - Filename, to take unsaved changes into account. In addition, I've fixed a couple of issues and introduced quality-of-life changes, which are all meticulously listed in the Mp3tag for Mac changelog. If something is unclear or sparks your interest, please don’t hesitate to ask.
It's a free update! You can update the Mac App Store version via the Update tab in the App Store app and the standalone version from within the app via File → Check for Updates.
And if you’re not yet using Mp3tag for Mac, you can always get the 7-day trial version — only days you’re using the app are counted.
Thank you for reading, your interest, and your support.
Enjoy and take care
— Florian
I've just released Mp3tag for Mac v1.9.1 with the following changes:
Fixed
  • Check for minimum required version of Mp3tag for a Tag Source resulted in misleading error messages since the previous version.
You can update the Mac App Store version via the Update tab in the App Store app and the standalone version from within the app via File → Check for Updates .
I've just released Mp3tag for Mac v1.9.2 with the following changes:
Changed & Improved
  • Further improved focus and default-button handling in Tag Sources search window.
  • Improved performance when selecting many files, which might be especially noticeable on files from network shares.
  • Added detection of invalid ID3v2.2 frames in ID3v2.3 and ID3v2.4 tags and translation to target revision if possible.
I've just released Mp3tag for Mac v1.9.3 with the following changes:
New
  • Added scripting function sort to sort parts of a given string delimited by a given delimiter string.
  • Added Matroska mappings for CATALOGNUMBER, ENCODERSETTINGS, TVEPISODE, TVNETWORK, TVSEASON, and TVSHOW.
  • Added using Discogs Release ID from clipboard when searching via Discogs Release ID Tag Source.
  • Added option to stop, skip, and retry with apply to all on errors when deleting files.
Changed & Improved
  • Added deletion of files if trashing is not supported by the underlying file system.
  • Changed to use T=50 Album als default target type for MKV Matroska video files.
  • Improved calculation of bitrate for CBR MP3 files with a Xing Info header.
  • Added removing of trailing empty data that is not part of the RIFF file structure when saving WAV files.
  • Updated Danish localization.
Fixed
  • Fixed error when writing WAV files that have trailing garbage data that is not part of the RIFF file structure.
I've just released Mp3tag for Mac v1.9.4 with the following change:
Fixed
  • Files located within folders that share the same name as the file were not handled correctly.
I've just released Mp3tag for Mac v1.9.5 with the following change:
Fixed
  • Previous inputs for Original and Replace were not stored in dropdown-history menus for action Replace.
  • Previous inputs for Regexp and Replace were not stored in dropdown-history menus for action Replace with Regular Expression.
  • Some dropdown-history menus used a font different from the regular system font.
  • Using a negative parameter at Tag-Sources function SayNChars did not work correctly.
  • If the search string used for Tag-Sources function FindInLine was not found, the internal index was at the last character of the line instead of past the last character of the line.
I've just released Mp3tag for Mac v1.9.6 with the following changes:
Changed & Improved
  • After opening Quick Look with the space bar, you can now navigate to the previous or next file using the up and down arrow keys without needing to refocus the file list. (#68501)
Fixed
  • Tag Sources functions SayNextNumber, SayDate, and SayDuration were too forgiving on some inputs.
I've just released Mp3tag for Mac v1.9.7 with the following changes:
New:
  • Added Remove Tag toolbar icon (available via Customize Toolbar...). (#69647)
Changed & Improved
  • Use the parent directory in File → Open... if the last opened directory is no longer available.
  • Added tag version display to Extended Tags when viewing individual files. (#69371)
  • Modified Extended Tags column sizing so the Field column only uses the necessary width.
  • Adjusted control sizes for compatibility with macOS 26 Tahoe.
  • When a Nero tag needs to be written for MP4, a minimal version is now used without duplicating other global metadata.
  • Added a workaround for an issue on certain NAS systems (e.g., ReadyNAS) where file descriptors can become invalid (EBADF, error 9). The workaround can be enabled by setting NetworkFileLockingEnabled -bool no via defaults. (#69560)
Fixed
  • Internal changes to ensure fields for format strings work with macOS 26 Tahoe. (#69601)
  • Scripting function $num(x,y) did not preserve a negative sign for the first parameter.
I've just released Mp3tag for Mac v1.9.8 with the following changes:
Changed & Improved
  • Save toolbar button and menu item are now always enabled when files are selected. (#69782)
Fixed
  • Added a workaround for an issue where toolbar symbols did not immediately update their enabled state on macOS 26 Tahoe when the File List selection was changed using the mouse.
I've just released Mp3tag for Mac v1.9.9 with the following changes:
New
  • App icon for macOS 26 Tahoe including dark, tinted, and clear variants.
Fixed
  • MP4 fields TOTALTRACKS and TOTALDISCS were not written, if accompanied TRACK and DISC were not changed (since v1.9.7). (#69808)
I've just released Mp3tag for Mac v1.9.10 with the following changes:
Fixed
  • MP4 gnre atom for GENRE used type identifier that was incompatible with Apple Music so that "Unknown Genre" was displayed instead of the actual genre (since v1.9.7). (#69825, #69850)
I've just released Mp3tag for Mac v1.9.11 with the following changes:
New
  • Added support for Traditional Chinese localization.
Fixed
  • Performance improvements at Convert → Text - Tag with large amounts of text. (#69906)
  • Enabled option to replace invalid NTFS characters also replaced slash character / in %_folderpath when constructing file names via Convert → Tag - Filename.
  • Scrolling to the end of a Tag Panel field with content exceeding the visible range wasn't possible via Cmd+Right Arrow after saving tags.
  • Premature end of processing Tag Sources when condition for while loops wasn't satisfied.
I've just released Mp3tag for Mac v1.9.12 with the following changes:
New
  • Added mp4_creation_time, mp4_creation_time_raw , mp4_modification_time, and mp4_modification_time_raw information fields to display MP4 mvhd creation and modification dates.
  • Added scripting function $dedup(x,y,c) to remove duplicated strings from x, separated by y, optionally using case-insensitive comparison if c is set to 1.
  • Added function SayFormat to Web Sources Framework.
  • Added support for importing COMPOSER from extra artist role Music-By for Discogs Tag Sources.
I've just released Mp3tag for Mac v1.9.13 with the following changes:
Changed
  • Minor adjustments to function SayFormat from Web Sources Framework.
Fixed
  • MP4 mean atoms with uncommon namespaces were no longer displayed (since v1.9.7).
