99% of the time I do 2-3 kinds of work. And each of them either benefits or requires different set of columns being displayed. And as such, sometimes I have to turn on and turn off the same columns during the same day. So I do the same dull task over and over again. And my list of columns has over 30 positions, from which this 99% of the time I use around 10, from which I use 5-6 [depending on the kinf of work I'm doing]
If I could save the currently selected [turned on] columns then I could load them [choose that setting] from some kind of list. And then go back to other set. And so on
I know there already is this "Utils" in columns window, with option for loading and saving profiles. But:
- it requires to go into a submenu [with only two positions to choose from]
- a lot of the Columns window has an empty space [that could be used for new stuff]
- those profiles store also the list of available columns [so every INI file can have different arrangement columns or even a list of different columns]
So why not:
- add "Save" [set] a "Load" [set] as a button in the same place as "New", "Delete", Move up", "Move down", "Hide"; ditching the "Utils"
- separate overall list of columns from saved profile; so that always one list of columns to choose from would show up
Of course then there would be a problem of missing columns, if for example in a set of them [in the INI file] would be a request for a column that was removed form the overall list. But that could be overcome very simply by making two lists: one overall and second with the selected columns. The overall list of columns could be even wiped out clean at some point, because INI file of a given set would still store columns that are meant to be displayed in a given profile. So the overall list would serve as a kind of menu [for preparing and modifying sets], being a separate entity [INI file in a different folder]
That would also make the view more clearer. In that sense that I could have those 30 something columns listed in the overall list, but this time in a [maybe] alphabetical order [if I choose such approach], and not is a chaotic order of often used positions. And the second list would have only those 5 or 6 columns really used in a given set. The overall list still would be crowded but the list-in-usage could be short
Such a change would also implicate the addition of buttons for coping columns between those two lists [the overall list and the active / loaded one], so that the user would not have to waste time to manually create or re-create a column in overall list if any column were to be removed but at the same time retained in one of the short lists
Also going further: some of those saved sets could be chosen to be turned [loaded] via an icon from the Toolbar. I know that or now it is not possible to choose icon on that Toolbar, and as such I could not have a separate icon for every setting that I would want there to be, but one extra icon could switch [circle] through all of the list of sets. That would make user go less into Columns window
