Actions and batch-operations
How to append the string " xyz" to the content of a tag field?
Create a new action in an existing action group and choose Format value as action type.
  • Field specifies the tag field the formatting rule should be applied to.
  • Format string must have the field placeholder for the field selected above and the string which should be appended.
Example:
If you want to append the string " xyz" to the current value of the comment field:
Action type: Format value
Field: COMMENT
Format string: %comment% xyz
You can use this also to add "xyz " in front of the tag value, combine fields or to copy one value to another field.
String-manipulations
Append Album Name at the beginning of the Title
Appending [xyz] does not work (Actions)
convert from tags to tags
Adding band name to album title?
Remove Album from Title
How to add the same text to the tag for all files
String Adding and Numbering Question
Exchange/Move/Copy values of tags
Rename file only if extension matches (.Mp3, .Flac, etc)
"Actions" variable questions
Convert automatically "comments" to "album"?
Adding Genres (not replacing)
Add year to end of album name
Where to enter scripting function?
How to Add/Remove one word from multiple songs names
New Feature Request
Complex manage featured artists, moving & copying between fields
Need help with Artist tag w/multiple files
Is it possible to append Extra info to the title of each song in an album at once?
Combine tags on filename
Insert Text in Credit Field
Append tag to variety of existing tags/files?
Format Comment Field with Bitrate?
Bulk Add/Remove extra information to Tag Fields?
Add [artistname] to [trackname] / Merge fields
Add text to comment
Add to a tag, but keep already existing
Compilations and modified titles to include artist in brackets
ORIGYEAR tag confusion!
Adding text to beginning of existing comment
Disc number Sequential Action
add genre to existing multi genre tags
iPod Touch lyrics tag as track info
Add "Cd #" to "%ALBUM%" for albums with multiple CDs
how to add names in end of file name
Wort anhängen
No Change in File Tags
Searhing artist in compilation albums
Append to existing title for batch of selected files?
Disc number from folder name
How to use <Reserved> correctly?
Add a txt to title
Revise Multiple Album Titles?
Appending to existing genres
How to add text to multiple existing tag fields at once
Add S(Series)E(Episode) to Track or Title
Simple request -- append one field to another
Applying information from one file to another based on file sequence
How do I add a "word" after the name of artists?
Pulling location from directory into an action
Appending the same string of text to a batch of track titles
Adding words to title in MP3 on multiple files at once
Year tag manipulation
How to import a custom action group from a file
In ganze Spalte ein Wort anhängen
Adding info to a tag
Adds a word to the end of each song
Add DR (Dynamic Range) value to album title
Help me stitch the year to the album name on the album name field
Add a string, not replace it
How to move a tag to another field
Tagfeld Kommentar - Informationen ergänzen
