Freedb and Web Sources
[WS Cover] Download Cover art
freedb web search update
[WS] MusicBrainz XML Webservice
Cover Art (again)
[WS] Last.fm
[WS] Discogs Web Service
[WS] RateYourMusic
Search Amazon by %artist%
Tagging from MusicBrainz
[WS] imdb
[WS] Discogs Album search + VA
Share your custom Actions
[WS] Metal Archives
Miscellaneous Export scripts
[WS] Import lyrics from websites
How to change .src using artist instead of album search for cover art
Sharing Actions
[WS] vgmdb
Export Problems
Re-Instating Cover Art
How to import?
[WS] Discogs (pone mod)
Export only exports to TXT
Import old settings
Server Errors
Problems with lyrics
How to create a replacement matrix in MP3Tag
problems with .src files
How to export actions you've created to share.
Windows 7
[X] Can't connect to the amazon webservices
Export / Backup Actions and Import to another PC
Automated sort order tags
Import lyrics from websites Issue
Can I save all 'Actions' created on one PC for use on another ?
any way to remove itunNORM from comments?
Loading custom action groups...
Customize Column abnormalities
Usage of "\data\actions" in program's directory?
Online Information doesn't work (freedb, etc...)
Newbie questions
Export Trouble
How to use Export?
where is usrfields.ini?
[WS] UtaiteDB.net
[WS] Fanart.TV
[WS] VocaDB.net
Mp3tag Export Splitter
Source tags using Discogs release ID?
[WS] Cue Sheets
dano export configs
juno records
Why won't my actions show up?
Export Configuration Archive
how do I use/run script?
Tag Sources no longer work
[X] information in amazon doesn't found by mp3tag
[F] "invalid data full line expected"
[new feature suggestion] Auto format uppercase/lowercase for some words in tags
Action group import/export
Export column view
Musicbrainz "Gone 410" - Error
Trouble With Lyrics
Rename
How to resolve connection issues to freedb or Web Sources?
First of all, make sure that Mp3tag has access to the internet. This can often be checked by using Help > Check for new version.... If you're getting a response there, you can be sure that the internet connection works.
If Mp3tag can't connect to the internet, please ensure that the Firewall on your system allows access for Mp3tag. Some routers also have program- or traffic-specific rules.
If you have still problems with accessing online resources, increase the timeout value at Options > Networking to 10 and try again.
How to use a *.src web source file?
Copy or move the *.src file to the configuration folder at
%APPDATA%\Mp3tag\data\sources
You can also just execute the openSourcesDirectory.bat file that automatically opens the correct folder. It either comes with the *.src file or can be downloaded from here.
You can now use the script from the Tag Sources menu or from the :mt_freedb: button.
Please visit the Web Sources category if you are interested in more scripts.
How to find the configuration folder?
Use File → Open configuration folder.
The configuration folder contains the following data:
  • Export configurations *.mte
    %APPDATA%\Mp3tag\export
  • Actions *.mta
    %APPDATA%\Mp3tag\data\actions
  • Web sources scripts *.src
  • Custom genres, column views and tools *.ini
  • Library (if enabled) *.db3
    %APPDATA%\Mp3tag\data\library
For a Standard installation, the configuration folder is at %APPDATA%\Mp3tag which usually expands to C:\Users\<username>\AppData\Roaming\Mp3tag.
For a Portable installation, the program directory is used to store the settings.
For a Microsoft Store installation, the configuration folder is at C:\Users\<Your Name>\AppData\Local\Packages\35795FlorianHeidenreich.Mp3tag_rf0p6xgxmspcc\LocalCache\Roaming\Mp3tag\
Discogs is reporting a 401 error: UNAUTHORIZED
In many cases, the problem can be fixed by correcting the system time. This is necessary, because the time is part of the OAuth authorization flow and the signature that is used to communicate with the Discogs API.
